Console mode
Revision as of 15:08, 6 October 2017 by G8GTZ (talk | contribs)
The Console provides a means to configure all aspects of the Portsdown Transmitter Software, as well as providing an interface to operate the transmitter.
Entering console mode
If your Portsdown transmitter is normally configured to boot up and be used in Touchscreen mode and you want to change some parameters such as station name, simply follow this procedure.
The process is very similar to initial set up and is done by using an external PC running an SSH Terminal application such as Putty.
  • Connect the RPi to the same network as your PC, and turn the Portsdown on. If you already have a touch screen on your Portsdown, note down the IP address displayed when the system boots.
If you do not have a touch screen connected use the IP Scanner program to find the IP address of your RPi.
Note, if the console menu does not appear and you end up at the Linux Command Line, you can get back to the Main Console Menu by typing: /home/pi/rpidatv/scripts/menu.sh menu
You can now make any changes you require (see initial setup for details on options) and as long as you do not change the autostart configuration, the Portsdown will automatically boot back in to Touchscreen mode when restarted.
Menu options
This page lists the menu options that are available as at Software Version 201704160.
                  Main Menu
 │                0 Transmit 437 Mhz, 333 KS, FEC 7/8.                            │
 │                1 Source   Select Video Source (DESKTOP selected)               │
 │                2 Output   Configure Output (QPSKRF selected)                   │
 │                3 Station  Station call setup                                   │
 │                4 Receive  Receive via rtlsdr                                   │
 │                5 System   System setup                                         │
 │                6 System 2 Advanced System Setup                                │
 │                7 Language Set Language and Keyboard                            │
 │                8 Shutdown Shutdown and reboot options                          │
       Source Menu
 │    ( ) CAMH264      Pi Camera, H264 Encoding                               │
 │    ( ) CAMMPEG-2    Pi Camera, MPEG-2 Encoding (for old Sat RX)            │
 │    ( ) FILETS       Play a Transport stream file (.ts)                     │
 │    ( ) PATERNAUDIO  JPEG Pictures From File (no audio)                     │
 │    ( ) CARRIER      Carrier with no Modulation                             │
 │    ( ) TESTMODE     Testmode for Carrier Null                              │
 │    ( ) IPTSIN       Transport stream from network                          │
 │    ( ) ANALOGCAM    Analog (EasyCap) Video Input                           │
 │    ( ) VNC          Show PC Desktop via VNC                                │
 │    (*) DESKTOP      Show Touchscreen or Raspberry Pi Display               │
                        Output Menu
 │                     1 SymbolRate  Symbol Rate Setup                        │
 │                     2 FEC         FEC Setup                                │
 │                     3 Output mode Output Mode                              │
 │                     4 PID         PID setup                                │
 │                     5 Frequency   Output frequency(MHZ)                    │
      FEC Menu
 |    ( ) 1  1/2                                                              │
 │    ( ) 2  2/3                                                              │
 │    ( ) 3  3/4                                                              │
 │    ( ) 5  5/6                                                              │
 │    (*) 7  7/8                                                              │
     Output Mode Menu
│    ( ) IQ           IQ output for Portsdown filter modulator board         │
│    (*) QPSKRF       UGLY Test Mode.  RF from pin 32. No modulator required.│
│    ( ) BATC         Stream to BATC.TV                                      │
│    ( ) STREAMER     Stream to other Streaming Facility                     │
│    ( ) DIGITHIN     Use Digithin Modulator Card                            │
│    ( ) DATVEXPRESS  Use DATV Express connected by USB                      │
│    ( ) IP           Transmit on IP network                                 │
             System Setup Menu
│            1 Autostart       Automatic startup                             │
│            2 Display         Display type                                  │
│            3 IP              IP Address                                    │
│            4 WiFi Set-up     SSID and password                             │
|            5 WiFi Off        Turn the WiFi Off                             │
│            6 Enable DigiThin Not Implemented Yet                           │
│            7 Set-up EasyCap  Set input socket and PAL/NTSC                 │
│            8 Audio Input     Select USB Dongle or EasyCap                  │
│            9 Update          Check for Updated rpidatv Software            │
     Autostart Menu
│    ( ) Prompt        Log-on to Linux Command Prompt                        │
│    (*) Console       Log-on to Portsdown Console Menu                      │
│    ( ) TX_boot       Boot-up to Transmit                                   │
│    ( ) Display_boot  Boot-up to Touchscreen Display                        │
│    ( ) Button_boot   Boot-up to Button Control                             │
     Display type Menu
│    ( ) Tontec35   Tontec 3.5 inches                                        │
│    ( ) HDMITouch  HDMI touchscreen                                         │
│    (*) Waveshare  Waveshare 3.5 A LCD (default)                            │
│    (*) WaveshareB Waveshare 3.5 B LCD (alternative)                        │
│    ( ) Console    Network Console                                          │
       Advanced System Setup Menu
│      1 Set Presets       For Touchscreen Frequencies                       │
│      2 Set Presets       For Touchscreen Symbol Rates                      │
│      3 ADF4351 Ref Freq  Set ADF4351 Reference Freq and Cal                │
│      4 ADF4351 Levels    Set ADF4351 Levels for Each Band                  │
│      5 DATV Express      Configure DATV Express Settings for each band     │
│      6 Contest Numbers   Set Contest Numbers for each band                 │
│      7 Viewfinder        Disable or Enable Viewfinder on Touchscreen       │
│      8 SD Card Info      Show SD Card Information                          │
│      9 Factory Settings  Restore Initial Configuration                     │
│      10 Back-up Settings Save Settings to a USB drive                      │
│      11 Load Settings    Load settings from a USB Drive                    │
│      12 Beta Software    Choose whether to use experimental software       │
                 Language Selection Menu
│                1 French Menus    Menus Francais                            │
│                2 English Menus   Change Menus to English                   │
│                3 German Menus    Menüs auf Deutsch wechseln                │
│                4 French Keyboard Needs reboot after setting                │
│                5 UK Keyboard     Needs reboot after setting                │
│                6 US Keyboard     Needs reboot after setting                │
           Shutdown Menu
│          1 Shutdown now        Immediate Shutdown                          │
│          2 Reboot now          Immediate reboot                            │
│          3 Exit to Linux       Exit menu to Command Prompt                 │
│          4 Restore TouchScreen Exit to LCD.  Use ctrl-C to return          │
│          5 Button Enable       Enable Shutdown Button                      │
│          6 Button Disable      Disable Shutdown Button                     │
