Minitiouner Hardware
How do I get started?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on this wiki page.
 The project had previously used several tuner types and a version 1 PCB and adapter cards - new builders should only use the Serit tuner and version 2 PCB.
  • The version 2 main PCB can be bought from the BATC shop.
  • The tuner or NIM. The Serit tuner covering 143 - 2450 MHz is available from the BATC shop
All other components such as Rs and Cs are available from normal suppliers. A parts list for the version 2 PCB is available on the V2 wiki page and can be used to order all other parts directly from Digikey.
MiniTiouner main PCB
There are 2 variants of the MiniTiouner main PCB which contains the power supply components for the 5, 3.3 and 1 volt rails. As of April 2017 new builders should only build version 2.
New builders should go to this MiniTiouner hardware Version 2 wiki page for more details, part list and construction tips.
Version 1 - before Feb 2017
USB module
If you buy a USB module from another source (not the BATC Shop) and need to program it, the instructions are here http://www.vivadatv.org/viewtopic.php?f=80&t=379.
Note - some people have noticed what appears to be a solder short between 2 pins on the IC on the USB module - see below - this is perfectly normal.
The NIM
inside a NIM
Fitting a lock detector
