Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the version 2 PCB described on this page along with a Serit tuner described here and available from the BATC shop.
If you already have version 1 MiniTiouner, then you probably don't need one unless you want a smaller board. (NOTE:The version 2 PCB ONLY takes the Serit tuner and you may be better off with the Serit adapter board).
- The USB interface is available ready programmed from the MiniTiouner category in the BATC shop.
- The version 2 main PCB is available from the MiniTiouner category in the BATC shop.
- The Serit tuner or NIM covering 143 - 2450 MHz is available from the MiniTiouner category in the BATC shop.
- The unit uses an adjustable MCP1826 as the 1v regulator, which can be hard to find and is available from the MiniTiouner category in the BATC shop.
Parts list and schematic
The parts list and schematic are available for download:
The small regulator module is available from ebay - search for "MP1584 step down buck regulator".
Setting up the hardware
Mike, G0MJW, has written some instructions on building and testing the board - download them here File:Notes on building the BATC v2 Minitiouner.pdf
On the air
