MiniTioune software
Software Installation
Connecting the hardware
It is absolutely essential you use a high quality cable or the program will frequently freeze and crash with no warning - the recommended cable is a Lindy Cromo Lindy cable USB 2.0 type A/mini-B 1m long.  https://www.lindy.co.uk/cables-adapters-c1/usb-c449/1m-cromo-usb-2-0-type-a-to-mini-b-cable-p6866
  • DVB mode - DVB-S or DVB-S2
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2. For ATV operation make sure the DVB-S box is ticked and not auto.
  • Place a jumper on J3, which is near the 12v power socket. Check that there is now 12v on the upper NIM F socket.
  • Connect the upper NIM socket to a Sky dish.
  • Start the MiniTioune software.
  • In the frequency setting area in the top left of the screen, put 09750000 into the OFFSET box.
  • Click the PLUS / MINUS indicator next to it so that it shows MINUS.
  • Put 10758000 into the FREQ box.
  • Put 22000 into the SR box.
Further down from the FREQ box, below the frequency buttons, check that DVB-S and Fplug-A are selected.
Other controls
Set of soft controls located at the bottom right of the screen.
A typical display from the Data reader
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
Web monitor
The web monitoring panel will now show your call sign and locator - tick the "auto" box and turn the monitor switch on.
Expert Mode
To be completed.....
