Minitiouner Hardware
How do I get started?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on this wiki page.
To build the unit you need to buy the following from the MiniTiouner category in the BATC shop and then download the free MiniTioune software.
  • The version 2 main PCB.
  • The Serit tuner covering 143 - 2450 MHz is available from the BATC shop
  • The hard to find MCP1826 1v regulator.
All other components such as Rs and Cs are available from normal suppliers and the 5v switched regulator module is available from ebay.
A parts list for the version 2 PCB is available on the V2 wiki page and can be used to order all other parts directly from Digikey.
Total project cost using new parts and including a nice Hammond enclosure is around £85.
MiniTiouner main PCB
There are 2 variants of the MiniTiouner main PCB which contains the power supply components for the 5, 3.3 and 1 volt rails.
New builders should go to this MiniTiouner hardware Version 2 wiki page for more details, part list and construction tips.
Version 1 - before Feb 2017
USB module
If you buy a USB module from another source (not the BATC Shop) and need to program it, the instructions are here http://www.vivadatv.org/viewtopic.php?f=80&t=379.
Note - some people have noticed what appears to be a solder short between 2 pins on the IC on the USB module - see below - this is perfectly normal.
The NIM
inside a NIM
Fitting a lock detector
