5.6 GHz
It is very easy (and low cost) to get on the air on 5.6GHz (the 6 cm amateur band) using the cheap modules intended to transmit “First Person Video” (FPV) back from drones to their operators. These units can be used without any modifications to get on air, and with a simple wifi plate or dish antennae and a clear line of sight path, can be used to can send pictures to stations using the same equipment over 50 Kms away.
Frequency choice
Equipment
Mounting the equipment
Transmit amplifiers
Several users have found these PAs to be "fragile" and you should always make sure the antennae is connected and all connectors done up tight before applying power.
Antenna change over relays
Reverse SMA
Antennas
Horizontal polarity has been chosen as the standard (wave guide needs to be vertical when feeding dishes)
Satellite dishes
It is also possible to use a satellite mini dish with a suitable feed such as a wave guide horn to the design by G4NNS - see here for construction details: http://myweb.tiscali.co.uk/g4nns/FeedHorn.html
The picture shows a Sky mini dish fed with a WA5VJB log period PCB feed http://www.wa5vjb.com/products1.html - these are available in the UK from G4DDK. http://www.g4ddk.com/Prices.html
Dishes of this size typically have a beam width of 4-8 degrees.
M1BKF found a very interesting 5.6GHz feed for standard f/d satellite dishes.
It contains what looks like a PCB yagi and is available from http://www.antennas-amplifiers.com/5.1-5.5-5.8GHz-WLAN-WiFi-Antenna/Feed-Illuminator-satellite-offset-dish-fd-0.5-0.8
DIY Biquad antennae
This web page http://buildyourownantenna.blogspot.co.uk/2014/07/double-biquad-sector-antenna-for-5-ghz-wifi.html has a well engineered double Biquad antennae with 13dBi gain.
Note in the picture G8JAN has directly connected the Tx module to the antennae to avoid co-ax losses.
Video equipment - Rx
Video squelch defeat
===Syncsmurf by PE1RQM=== - kits are available details on the webpage here.
Results are very impressive:
eachines FPV recorder
Several people have reported that they are using these devices, available from various sites, and as well as defeating the monitor blue screen by inserting syncs on noise they have a single push button record facility. They record to an SD card which can be removed and the files viewed on a PC but users report that you need to use a good SD card and have had problems with Kingston and Sandisk are preferred.
Video sync processor
Or any video sync processor may be useable such as the Advanced Converter Enhancer used by many stations on 23cms FM.
Video equipment - Tx
An old camcorder with a yellow phono video out socket is an ideal video and audio source for the transmitter.
Don't forget you will need to display your call sign to remain legal. This can be a video generator, a jpeg card reader with video out, or a piece of card with your call sign scribbled on it!
Media card reader
A simple way to generate test patterns is to use a media card reader loaded with .jpg files - these are available on several sites, just search for "sd card media av player" but make sure you get one with PAL video out.
PicDream
The Picdream project uses a single PIC chip and 4MHz crystal to generate a black and white test pattern - simple but effective - original project was described in CQ-TV 180 and re-printed in CQ-TV 247.
The PIC code is available for download here: batc.org.uk/cq-tv/software/picdream.zip
Raspberry Pi - PA3CHM image generator
CQ-TV 247 published details of a simple Rpi based test card generator by Ernest PA3CHM.
Full details are on his website: http://www.pa3hcm.nl/?p=248
Raspberry Pi - Portsdown patterns
The BATC Portsdown project can be configured to deliver composite video and audio out from the Rpi multi-jack plug.
This can be test patterns, Rpi desktop or the Portsdown camera and microphone - see this wiki page for more details making the Rpi the only piece of video / audio equipment you need to drive the 5.6GHz transmitter.
On the air
FM voice only
Several stations in the Gloucester and Bolton area are using these units for wide band FM voice only. This is achieved by simply putting high level (1v p to p) audio on the yellow video tx phono - this modulates the main high level carrier with audio rather than video (ignore the 2 red and white audio phono connectors). On rx, just connect the yellow phono to a line in audio amp.
You do it this way because audio sub carriers are 20 dB down on the main carrier. However, as it is using the same bandwidth rx and tx system, performance will be no better than FM video - ideally the 480MHz rx IF would be tapped off in to an SDR or narrow band receiver to give significantly enhanced (+20db?) narrow band performance.
Activity hot spots
There is a Google map showing approximate locations of stations thought to be active on 5.6GHz FM - if you are on 5.6GHz, you can add or edit your station: https://www.google.com/maps/d/u/0/edit?mid=1e4keFSFWy6wLUQNF3IT3n6h90eU&ll=52.39133141509076%2C-1.8917942000000494&z=7
Know users include:
- Ludlow, Shropshire = G8XYJ
- Yorkshire = G8BYN
More information
Technical information
SM201R
S meter output
Tx and Rx perfomance
Channel Listings
