Revision as of 18:21, 19 November 2017 by G8GTZ (talk | contribs)
Whilst the project has previously used several tuner types and a version 1 PCB and adapter cards, new builders should only use the version 2 PCB described on this page.
NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
Parts list and schematic
The parts list and schematic are available for download:
File:SERIF.pdf
File:Seritpartsv3.xls
The small regulator module is available from ebay - search for "MP1584 step down buck regulator".
Setting up the hardware
Mike, G0MJW, has written some instructions on building and testing the board - download them here File:Notes on building the BATC v2 Minitiouner.pdf
On the air
