Initial setup
Important note - the Portsdown transmitter has been designed to "work out of the box" but you do have to run through the initial set up procedure described on this page.
Initial set up
Once you have a Rpi and an SD card with the Portsdown firmware installed - either from the BATC shop or by following the instructions in this section of the user guide - the system must be initially setup. This done using an external PC connected to the Rpi over your standard home network.
Using a network lead (not wifi at this stage), connect the RPi to the same network as your PC, install the SD card and turn the RPi on (you do not need a keyboard, mouse or monitor connected to the Rpi). If you are using Portsdown software 201704160 or later and have a touchscreen fitted, your RPi's IP address should appear on the touchscreen 20 seconds after power-on. Make a note of it.
If you are using Portsdown software 201704160 or later and have a touchscreen fitted your RPi's IP address should appear on the touchscreen 20 seconds after power-on. If you have an older software version or no touchscreen, you will need to run the IP Scanner program on your PC - download it from Advanced IP Scanner and scan for devices and after a few seconds it will list all the devices on your network including one from the Raspberry Pi foundation - this is your RPi so note down the IP address listed against it.  You can now close the IP scanner program.
Running the setup menu
Now you need to log on to your Rpi using a PC over your home network (Do NOT connect a keyboard and monitor directly to the RPi). To do this you need to download an SSH Terminal application such as Putty to edit the set up menu - make sure you use a recent version of putty or it may reject the Rpi security certificate.
There is a video on the BATC YouTube channel showing how to do these processes - please watch it before posting any questions on the forum, but note you may NOT need to do the first step (finding the IP address).
Connect your touchscreen and any other peripherals such Pi camera and audio dongle but do not connect a monitor or keyboard to the Raspberry Pi.
Console menu
You now need to set up your Portsdown using the Console Menu - remember these instructions as you made need them to change configurations in the future.
  • The Portsdown console menu will start automatically, and you should see the following screen on the PC: At the same time, a BATC logo should appear on the touchscreen. If there is nothing on the touchscreen, try a shutdown, power-off and re-start.
  • System Setup Autostart. You can select how you want your RPi to start up.
  • Language. The menu language can be changed to French or German (or back to English) from this menu.
