Software Capability Matrix
The list of modes that can be generated by the Portsdown software and hardware is extensive. All modes have different capabilities. This table is an attempt to summarise what is possible with software version 201803060 and later. Please read with the notes below.
| Encoding | Source | Audio | 4:3 | 16:9 | 720p | 1080p | Viewfinder | Streaming |
| MPEG-2 | Pi Cam | Yes | Yes | Yes | Yes | No | Yes | Yes |
| MPEG-2 | Comp Vid | Yes | Yes | Yes | No | No | No | Yes |
| MPEG-2 | TCAnim | Not Available | ||||||
| MPEG-2 | Test Card | Yes | Yes | Yes | Yes | No | Yes | Yes |
| MPEG-2 | Pi Screen | Not Available | ||||||
| MPEG-2 | Contest | Yes | Yes | No | No | No | Yes | Yes(!) |
| MPEG-2 | Webcam | Yes | Yes | Yes | Yes | No | No | Yes |
| MPEG-2 | C920 | Yes | Yes | No | Yes | No | No | Yes |
| H264 | Pi Cam | No | Yes | No | No | No | Yes | Yes |
| H264 | Comp Vid | No | Yes | No | No | No | No | Yes |
| H264 | TCAnim | No | Yes | No | No | No | Yes | No |
| H264 | Test Card | No | Yes | No | No | No | Yes | No |
| H264 | Pi Screen | No | Yes | No | No | No | Yes | No |
| H264 | Contest | No | Yes | No | No | No | Yes | No |
| H264 | Webcam | No | Yes | No | No | No | No | Yes |
| H264 | C920 | Yes | Yes | No | Yes | Yes | No | No |
| As Req | IPTS In | Yes | Yes | Yes | Yes | Yes | No | No |
| As Req | File TS | Yes | Yes | Yes | Yes | Yes | No | No |
NOTES
Please feel free to contribute your experiences to this page.
1. The H264 modes (apart from C920) transmit a 704 x 576 image from the Source at SRs from 125KS up to over 4MS with the Portsdown filter-modulator board. No sound is transmitted.
2. The audio on the MPEG-2 test card and contest modes suffers from occasional break-up. This is due to insufficient CPU processing power in the Raspberry Pi 3.
3. A moving viewfinder is only available in Pi Cam and TCAnim (the animated test card with the bouncing balls) modes.
4. The Waveshare Touchscreen is only updated a few times each second, so movement will be displayed in a jerky fashion. The transmitted picture is smoother.
5. The Caption overlay (at top left) is only available in MPEG-2 modes. However the callsign is displayed on H264 test cards and contest numbers.
6. The 16:9 mode is difficult to generate and with the Composite Video source the video is down-sampled to 512x288 to achieve the correct aspect ratio.
