8-Band RF Output Switch
Revision as of 22:35, 24 March 2018 by G8GKQ (talk | contribs)
For those of you who want to drive Microwave transverters from your Portsdown or need a higher drive level, the team have developed an 8-Band RF output switch that includes an RF amplifier. It is designed to be used with the Output Attenuator (see below). It will be capable of amplifying the variable level from the attenuator providing up to 10 dBm and switching it to separate amplifiers for the 70, 144, 437 and 1255 MHz bands, and to 4 transverters for the higher bands. PCBs are available from the BATC Shop.
The initial design was as shown above - the first batch of boards will be supplied in this form. The initial (V1.0) circuit is here: Media:8 BAND RF SWITCH V1-0 SCH.pdf. The first board layout is here: Media:8 BAND RF SWITCH V1-0 SS.pdf.
The original parts list, which has not yet been updated, and has only been checked against the DigiKey Part Numbers, is here: File:8 BAND RF SWITCH V1-0 PARTS.xls
  3. Wire a 78L05 regulator with its input from the 12V supply and its output to the point marked 5VA.
  4. The input attenuator should be set up with R1=R2=68 ohms, and R3=220 ohms. If you need 10 dBm output on 1255 MHz, this can be achieved by adding a series combination of 68 ohms and 2.7 pf across R3
The new circuit (will be published as soon as the design is validated.
