Minitiouner Hardware
Revision as of 11:17, 16 April 2018 by G8GTZ (talk | contribs)
There are several versions of the MiniTiouner hardware, all of which use the same MiniTiouner software and have very similar functionality. This page describes the 2 versions sold by the BATC:
  • Version 1 sold by BATC available up to February 2017
  • Version 2 sold by BATC and is the current version described on this page. Sold as an easy to build home construction project with options to add an LCD display and simultaneously decode a 2nd channel.
MiniTioune-Express is sold by the DATVexpress team as a ready built unit. Does not have the option for LCD or 2nd channel decode.
MiniTiouner Pro is sold by the French Amateur Radio organisation REF as a completed unit to it's members and does have LCD and dual stream receiver possibility
The BATC Minitiouner hardware is designed for home construction and consists of the 3 main components described on this wiki page.
How do I get started?
To build the unit you need to buy the following from the MiniTiouner category in the BATC shop
  • The version 2 main PCB.
  • The Serit tuner covering 143 - 2450 MHz
  • The hard to find MCP1826 1v regulator.
All other components such as Rs and Cs are available from normal suppliers and the 5v switched regulator module is available from ebay.
A parts list for the version 2 PCB is available on the V2 wiki page and can be used to order all other parts directly from Digikey.
Total project cost using new parts and including a nice Hammond enclosure is around £85.
New builders should go to this MiniTiouner hardware Version 2 wiki page for more details, part list and construction tips.
MiniTiouner main PCB
There are 2 variants of the MiniTiouner main PCB which contains the power supply components for the 5, 3.3 and 1 volt rails.
Version 1 - before Feb 2017
USB module
If you buy a USB module from another source (not the BATC Shop) and need to program it, the instructions are here http://www.vivadatv.org/viewtopic.php?f=80&t=379.
Note - some people have noticed what appears to be a solder short between 2 pins on the IC on the USB module - see below - this is perfectly normal.
The NIM
inside a NIM
Fitting a lock detector
