IARU ATV contest
Revision as of 21:19, 19 May 2018 by G8GKQ (talk | contribs)
The 2018 event is on 10/11 June - the contest starts at 1 pm UK time on the Saturday and runs through until 7 pm on the Sunday, so there is plenty of time to get on the air.
This is an international contest and ATV operators in all countries in IARU region 1 enter and a table of results is produced showing a lkeague table of entries based on bands used and number of entries from each country.
Who can enter?
The rules allow for “roving” stations, so there is no reason why you should not operate from home on one day, and go out portable on another, or even use multiple portable sites. Just remember to use new 4-digit codes from each location (and to ask for new codes from any station that you have worked before).
What Bands are in Use?
The IARU Contest involves all the bands above 437 MHz. For 2018, the BATC is running a parallel contest for 146 MHz entries. The rules are exactly the same as the IARU contest and contacts should be scored at 2 points per km (for 2-way).
The numbers can be scribbled on a piece of paper or computer generated. The Portsdown system can automatically generate a different set of numbers for each band, but you need to set the numbers before the Contest. The default Portsdown numbers are not valid for contest use; full details of how to set them are here: Portsdown Contest Numbers.
Signal reports
Time of contest
The contest rules refer to times in UTC: this is Universal Coordinated Time (the abbreviation comes from the French translation which is internationally accepted). Many of us will know this as Greenwich Mean Time (GMT), which is the clock time in the UK during the winter, but one hour behind in the Summer when we use British Summer Time (BST). This is why the International Contest starts at 1pm and finishes at 7pm for us.
Submitting an entry
To submit an entry please use the Excel Spreadsheet here https://www.iaru-r1.org/images/VHF/atv/ATV_contest_log_-_ATV_yourcall_YYYYMMDD.xls and send it to contests@batc.tv. Alternatively, simply send in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received.
Are There Any Prizes?
For the 2018 Contest the BATC will be making the following awards to UK-based stations:
A £50 Amazon Voucher to the winner of the BATC 146 MHz Contest A £50 Amazon Voucher to each station in the Best DX 2-way 5.6 GHz Contact A £50 Amazon Voucher to the transmitting station using a Portsdown system received at the the furthest distance (any band).
Awards will be presented during the BGM at CAT 18 (on the Sunday).
More information
