IARU ATV contest
The 2018 event is on 9/10 June - the contest starts at 1 pm UK time on the Saturday and runs through until 7 pm on the Sunday, so there is plenty of time to get on the air.
Who can enter?
What Bands are in Use?
The IARU Contest involves all the bands above 437 MHz. For 2018, the BATC is running a parallel contest for 146 MHz entries. The rules are exactly the same as the IARU contest and contacts should be scored at 2 points per km (for 2-way).
Signal reports
Time of contest
Submitting an entry
Ideally you will submit an entry on the official Excel Spreadsheet which you can download from here here https://www.iaru-r1.org/images/VHF/atv/ATV_contest_log_-_ATV_yourcall_YYYYMMDD.xls
Once you have completed it please email it to contests@batc.tv.
Alternatively, simply email in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received to contests@batc.tv.
Contact scoring
- For contacts on the 435 MHz band: 2 points/kilometre
- For contacts on the 1.3 GHz band: 4 points/kilometre
- For contacts on higher bands: 10 points/kilometre
Note: for scoring purposes all valid contacts shall be deemed to have taken place over a distance of at least 5 kilometres, even if the two stations in contact have the same or adjacent IARU locators.
Note that one way QSOs, for example where someone only has a receiver, do count and are awarded half points for both stations and you can claim points for a QSO even if the other station does not submit an entry.
2017 contest results
The number of stations entering the contest is increasing each year:
2014 = 33
2015 = 42
2016 = 52
2017 = 95
Are There Any Prizes?
For the 2018 Contest the BATC will be making the following awards to UK-based stations:
- A £50 Amazon Voucher to the winner of the BATC 146 MHz Contest
- A £50 Amazon Voucher to each station in the Best DX 2-way 5.6 GHz contact
- A £50 Amazon Voucher to the transmitting station using a Portsdown system received at the the furthest distance (any band).
Awards will be presented during the BGM at CAT 18 (on the Sunday).
More information
