Account Dashboard
Once you have logged in as a member (see this wiki page) you can access and change a lot of details on your membership account.
The Account Dashboard which can be found on the left hand menu on the membership summary page (the default page after you log in).
Update personal details
In this section you can change your name ,email address and callsign. Note you cannot update your membership number.
Change your password
To manually change your password, you will need to enter your current password and then enter and confirm the new password. When you press "update password" an email will then be sent to your registered email address confirming the change.
Addresses
This section of the Account dashboard allows you to change your home address and any delivery address you have set up - click on the "edit" button and you will be taken to a separate screen where you can change any details.
Streaming details
As a member you are automatically allocated a streaming channel on the BATC streaming service. This section of the account dashboard allows you to change various parameters on your channel. If you do not wish to use the streaming service you can ignore this section of your Account summary.
Chat nick name
Stream Title
Stream output URL
This is the direct URL you can give to people to watch your stream - you cannot change this field.
Note - the full URL is made up of the https address above the grey box PLUS the text in the grey box (without any spaces between the 2).  For example "https://batc.org.uk/live/g8gtz"
Stream input URL
This is the stream input URL which must be put in to your streaming encoder - you should note pass this on to anyone else.
For Adobe media encoder put the "rtmp://rtmp.batc.org.uk/live/streamname" string above the grey box in to... and the text in the grey in to...
For Vmix put the "rtmp://rtmp.batc.org.uk/live/streamname" string above the grey box in to... and the text in the grey in to...
For Portsdown put the "rtmp://rtmp.batc.org.uk/live/streamname" string above the grey box in to... and the text in the grey in to...
For OBS put the "rtmp://rtmp.batc.org.uk/live/streamname" string above the grey box in to... and the text in the grey in to...
Stream type
Stream options
You can decide if your stream is listed in the streamer channel list, if the Chat window appears on the side of your channel video player and if quests can log on to the chat on your channel.
Stream type
You can decide if your stream is sent from the server in Flash or HTML5 - the benefit of Flash is very low delay but HTML5 are veiwable on any device including iphones and ipads. Note that transcoding is done in the server and you do not have to change any settings on your encoder.
Stream description
This is a free format text box which allows HTML and is used to display text and links below your video player window.
