The new streamer
Revision as of 15:47, 27 May 2018 by G8GKQ (talk | contribs)
The new BATC streamer is integrated in to the main BATC website - all members are allocated a streaming channel which is configurable from the account dashboard.
Streamer channel list
The player page
Configuring your channel Logged in members can configure their channel on the member's account dashboard.
Editing your stream description
Channel types Details on members, repeaters and special event channels and how to get one.
Streaming from the Portsdown to the new Streamer
  6. Enter your stream name (callsign) in lower case, followed by a hyphen and then the 6 character stream key. For example g8gkq-xyzabc
