The new streamer
Revision as of 15:54, 27 May 2018 by G8GKQ (talk | contribs) (→Streaming from the Portsdown to the new Streamer)
The new BATC streamer is integrated in to the main BATC website - all members are allocated a streaming channel which is configurable from the account dashboard.
Configuring your channel Logged in members can configure their channel on the member's account dashboard.
Editing your stream description
Channel types Details on members, repeaters and special event channels and how to get one.
- Log on into Console mode and from the Menu select "3 Output"
- In the Output Parameters Menu select "3 Output Mode"
- In the Output Type menu use the down arrow to highlight "Streamer" and press the space bar and then enter.
- The correct stream URL of rtmp://rtmp.batc.org.uk/live should already be entered.
- Press enter to bring up the stream key page
- Enter your stream name (callsign) in lower case, followed by a hyphen and then the 6 character stream key. For example g8gkq-xYzaBC
- Press enter to get back to the main menu.
