Encoder settings
Jump to navigation
Jump to search
To stream to the new server you must first enter stream URL and name details in to your encoder - these details are different for every channel and can be found on your members account dashboard.
Streaming from the Portsdown to the new Streamer
- Log on into Console mode and from the Menu select "3 Output"
- In the Output Parameters Menu select "3 Output Mode"
- In the Output Type menu use the down arrow to highlight "Streamer" and press the space bar and then enter.
- The correct stream URL of rtmp://rtmp.batc.org.uk/live should already be entered.
- Press enter to bring up the stream key page
- Enter your stream name (callsign) in lower case, followed by a hyphen and then the 6 character stream key. For example g8gkq-xYzaBC
- Press enter to get back to the main menu.
