Configuring your channel
Revision as of 05:31, 28 May 2018 by G8GTZ (talk | contribs)
  • To configure your streaming channel you will need to log in as a member and then go to your account dashboard - see this page for more details see for more details.
Chat nick name
Stream Title
Stream output URL
This is the direct URL you can give to people to watch your stream - you cannot change this field.
Note - the full URL is made up of the https address above the grey box PLUS the text in the grey box (which is the name stream) without any spaces between the 2.
Stream input URL
This is the stream input URL which must be put in to your streaming encoder - you should not pass this on to anyone else.
The stream url is made up as follows - "rtmp://rtmp.batc.org.uk/live/xxxxx-yyyyy" where xxxx = the stream name listed in the first grey box and yyyy which is the key listed in the second box.
The following examples are based on the above screen shot:
For Adobe media encoder put the "rtmp://rtmp.batc.org.uk/live/" string above the grey box in to... and the text "g8gkq-abcxyz" in the grey box in to...
For Vmix put the "rtmp://rtmp.batc.org.uk/live/" string above the grey box in to the "URL" field and the text "g8gkq-abcxyz" in to "stream Name or key" box.
For Portsdown put the "rtmp://rtmp.batc.org.uk/live/" string above the grey box in to... and the text "g8gkq-abcxyz" in the grey box in to...
Stream type
Stream options
Streaming type
The Streaming Type can be set to Flash or HTML5. Flash has the advantage of minimal delay, but is not compatible with the stock browser on some devices. (Flash will need specifically enabling in Chrome, Firefox and Edge browsers). HTML5 works with all modern browsers, including iphones and ipads but is subject to a 10 - 20 second delay.
Stream description
This is a free format text box which allows HTML and is used to display text and links below your video player window.
