Configuring your channel
  • To configure your streaming channel you will need to log in as a member and then go to your account dashboard - see this page for more details on your account dashboard - scroll down on the page to Streaming details.
Chat nick name
Stream Title
Stream output URL
This is the direct URL you can give to people to watch your stream - you cannot change this field.
Note - the full URL is made up of the https address above the grey box PLUS the text in the grey box (which is the name stream) without any spaces between the 2.
Stream input URL
This is the stream input URL which must be put in to your streaming encoder - you should not pass this on to anyone else.
The stream url is made up as follows - "rtmp://rtmp.batc.org.uk/live/xxxxx-yyyyy" where xxxx = the stream name listed in the first grey box and yyyy which is the key listed in the second box.
Streaming from the Portsdown
Using Adobe Media encoder
For Adobe media encoder put the "rtmp://rtmp.batc.org.uk/live/" string above the grey box in to... and the text "g8gkq-abcxyz" in the grey box in to...
Using Vmix
For Vmix put the "rtmp://rtmp.batc.org.uk/live/" string above the grey box in to the "URL" field and the text "g8gkq-abcxyz" in to "stream Name or key" box.
Using OBS
Stream type
Stream options
Streaming type
The Streaming Type can be set to Flash or HTML5. Flash has the advantage of minimal delay, but is not compatible with the stock browser on some devices. (Flash will need specifically enabling in Chrome, Firefox and Edge browsers). HTML5 works with all modern browsers, including iphones and ipads but is subject to a 10 - 20 second delay.
=tream description
The stream description is the area below the video player and text chat windows on your channel page. This area can be used by you to describe your channel and give more details of your group or repeater.
It is a Free text area and can include HTML - we recommend you use an external HTML editor such as https://html-online.com/editor/ to get the correct look and then paste the code in to the space.
Please note any embedded content such as maps and time clocks etc from other sites need to use an SSL connection and have an https:// address.
