IARU ATV contest
The 2018 event is on 9/10 June - the contest starts at 1 pm UK time on the Saturday and runs through until 7 pm on the Sunday, so there is plenty of time to get on the air.
Who can enter?
What Bands are in Use?
The main IARU Contest includes all the amateur bands above 400 MHz.
This is because only the UK have the 146MHz band - however, for 2018, the BATC is running a parallel contest for 146 MHz entries. The rules are exactly the same as the IARU contest and contacts should be scored at 2 points per km (for 2-way) and there will be an award for the top stations.
Signal reports
Time of contest
Submitting an entry
Ideally you will submit an entry on the official Excel Spreadsheet which you can download from here here https://www.iaru-r1.org/images/VHF/atv/ATV_contest_log_-_ATV_yourcall_YYYYMMDD.xls
Entries for 146 MHz should be submitted on a separate spreadsheet which you can download from here: File:146_yourcall_YYYYMMDD.xls
Alternatively, simply email in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received to contests@batc.tv.
Contact scoring
  • For contacts on the 146 MHz band: 2 points/kilometre (BATC Contest only)
2017 contest results
The number of stations entering the contest is increasing each year:
2014 = 33
2015 = 42
2016 = 52
2017 = 95
Are There Any Prizes?
For the 2018 Contest the BATC will be making the following awards to UK-based stations:
  • A £50 Amazon Voucher to the winner of the BATC 146 MHz Contest
  • A £50 Amazon Voucher to each station in the Best DX 2-way 5.6 GHz contact
  • A £50 Amazon Voucher to the transmitting station using a Portsdown system received at the the furthest distance (any band).
Awards will be presented during the BGM at CAT 18 (on the Sunday).
More information
