Revision as of 16:45, 5 July 2018 by G8GTZ (talk | contribs)
  • The Serit tuner or NIM covering 143 - 2450 MHz is available from the MiniTiouner category in the BATC shop. NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
Parts list and schematic
The parts list and schematic are available for download:
File:SERIF.pdf
File:Seritpartsv3.xls
The small regulator module is available from ebay - search for "MP1584 step down buck regulator".
Setting up the hardware
Mike, G0MJW, has written some instructions on building and testing the board - download them here File:Notes on building the BATC v2 Minitiouner.pdf
On the air
