To build the unit you only need to buy the following components from the BATC shop [[1]] and then download the free MiniTioune software.
  • The USB interface ready programmed.
  • The version 2 main PCB.
  • The Serit tuner or NIM covering 143 - 2450 MHz. NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
  • The unit uses an adjustable MCP1826 as the 1v regulator, which can be hard to find.
Parts list and schematic
The parts list and schematic are available for download:
File:SERIF.pdf
File:Seritpartsv3.xls
The small regulator module is available from ebay - search for "MP1584 step down buck regulator".
MiniTiouner version 8 software
A small modification must be carried out before this version 2 hardware can be used with MiniTiouner version 8.
A 10k resistor must be fitted between Pin 19 on the USB module and ground as shown in the pictures by G7JTT and G1MEG.
G1MEG 300px\G7JTT
Setting up the hardware
Mike, G0MJW, has written some instructions on building and testing the board - download them here File:Notes on building the BATC v2 Minitiouner.pdf
On the air
