MiniTioune software
Revision as of 08:06, 6 July 2018 by G8GTZ (talk | contribs)
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software.
Version 8
You will to do a small modification to the hardware to run Version 8 software - see MiniTiouner_hardware_Version_2#MiniTiouner_version_8_software
Version 7
Version v0.6 or newer is the version you will need if you have built a MiniTiouner Version 2 board with a Serit tuner (or a Serit tuner on a version 1 board with adapter card).
Connecting the hardware
It is absolutely essential you use a high quality USB cable or the program will frequently freeze and crash with no warning
The recommended cable is a Lindy Cromo Lindy cable USB 2.0 type A/mini-B 1m long.  https://www.lindy.co.uk/cables-adapters-c1/usb-c449/1m-cromo-usb-2-0-type-a-to-mini-b-cable-p6866
  • DVB mode - DVB-S or DVB-S2
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2. For ATV operation make sure the DVB-S box is ticked and not auto.
The 3 "lights" at the bottom left of the screen should now turn green, the meters should indicate signal level and MER, you should see dots in the 4 quadrants of the constellation window and the Viterbi error bar graph should go green.
  • Place a jumper on J3, which is near the 12v power socket. Check that there is now 12v on the upper NIM F socket.
  • Connect the upper NIM socket to a Sky dish.
  • Start the MiniTioune software.
  • In the frequency setting area in the top left of the screen, put 09750000 into the OFFSET box.
  • Click the PLUS / MINUS indicator next to it so that it shows MINUS.
  • Put 10758000 into the FREQ box.
  • Put 22000 into the SR box.
Other controls
TT switches 1.JPG Set of soft controls located at the bottom right of the screen.
TT data.jpg A typical display from the Data reader
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
Web monitor
Webmon.JPG The web monitoring panel will now show your call sign and locator - tick the "auto" box and turn the monitor switch on.
Expert Mode
To be completed.....
Software Installation V7 and before only
