Using LimeSDR with Portsdown
Being updated for upcoming release 201811300
Software version 201811300 introduces support for the Lime SDR Mini and the Lime SDR USB. Due to the limited CPU power of the Raspberry Pi, many LimeSDR transmit modes are limited to 1MS and below. For higher SRs, use of the Portsdown Filter-modulator board is recommended.
Powering the Lime
The LimeSDR (both Mini and USB versions) has a greater power consumption than the RPi can comfortably power from its USB Port, so a powered USB Hub should be used to provide power to the Lime.
Installing the Lime Software
The LimeSuite software version 18.10.0 is loaded as part of the normal Portsdown build and update process. Once installed, you can use your Portsdown to update the firmware and gateware on your LimeSDR (Mini or USB) to the compatible version.
Lime Configuration Menu
Selecting "LimeUtil Info" displays the current version of LimeSuite. The "Update Lime FW" button updates the Lime SDR firmware and gateware to the appropriate version for the installed LimeSuite. For Portsdown software version 201811300, the correct versions are shown below. You should see exactly the same screen after selecting "Lime FW Info".
The Lime firmware/gateware version that works with the Portsdown also works with the current version of DATV Express.
Transmitting
Select Lime Mini or Lime USB from the "Output to" Menu. The detected device should be "not greyed out". On Menu 1, you will see the Lime Gain button for the appropriate band (distinct Lime Gains between 0 and 100 are stored for each band). This has yet to be calibrated, but a setting of 88 is a good starting point for between 1 and 5 dBm of output at 437 MHz.
Limitations
There is a failure mode where the LimeSDR refuses to transmit anything other than a carrier, or does not respond at all. It has not been possible to overcome these failures yet in software; the solution is to power down the LimeSDR (by disconnecting the power and USB leads, and then to reconnect them.
The BATC 4-band and 8-band PTT drive and RF switching boards should continue to be used with the Lime. They can either be connected to the RPi GPIO or to the Lime FPGA GPIO. GPIOs 0, 1 and 2 give the same signals as the RPi Band LSB, NSB and MSB. GPIO 7 gives the PTT signal. These can be taken from J5 on the LimeSDR Mini https://wiki.myriadrf.org/LimeSDR-Mini_v1.1_hardware_description or J18 on the LimeSDR USB https://wiki.myriadrf.org/LimeSDR-USB_User_Guide. The pin connections on the LimeSDR USB J18 are the same as those detailed for the LimeSDR Mini J5 here: https://wiki.myriadrf.org/LimeSDR-Mini_v1.1_hardware_description.
I was really impressed that, in response to a request from me, MyriadRF updated their drivers: https://discourse.myriadrf.org/t/limesdr-mini-gpio-read-not-supported/3510 allowing me to get the Portsdown to use these LimeSDR GPIOs.
Acknowledgements
