8-Band RF Output Switch
Revision as of 19:36, 15 December 2018 by G4FRE (talk | contribs)
For those of you who want to drive Microwave transverters from your Portsdown or need a higher drive level, the team have developed an 8-Band RF output switch that includes an RF amplifier. It is designed to be used with the Output Attenuator (see below). It will be capable of amplifying the variable level from the attenuator providing up to 10 dBm and switching it to separate amplifiers for the 70, 144, 437 and 1255 MHz bands, and to 4 transverters for the higher bands. PCBs are available from the BATC Shop.
Version 2 PCBs
The Current PCBs from the BATC Shop are Version 2.2. The previous version, V2.1 requires 2 minor corrections during construction. The grounded ends of R1 and R2 on the input attenuator need properly connecting to ground. Thanks to Colin G4EML for spotting this and pointing out that this can be corrected by scraping away some of the solder resist next to the pads and adding a blob of solder to connect the resistors to ground as shown in his picture here:
The current batch of PCBs from the BATC Shop are version 2.2, which have this fault corrected. The circuit for Version 2.1 and 2.2 PCBs is here: Media:8 BAND RF SWITCH V2-1 SCH.pdf.
Version 1 PCBs
The initial design was as shown above - the first batch of boards will be supplied in this form. The initial (V1.0) circuit is here: Media:8 BAND RF SWITCH V1-0 SCH.pdf. The first board layout is here: Media:8 BAND RF SWITCH V1-0 SS.pdf.
The original parts list, which has not yet been updated, and has only been checked against the DigiKey Part Numbers, is here: File:8 BAND RF SWITCH V1-0 PARTS.xls. This parts list does not yet include components for the input attenuator.
Usage and Performance
The 8-way switch is intended to be used in association with the digital attenuator described here https://wiki.batc.org.uk/Output_Attenuator .
Typical system output levels with the digital attenuator connected to the output of the filter modulator board, and followed by the 8-way switch are shown below. Output levels and shoulder levels with the attenuator set to 0 dB and 3 dB are included.
Freq Level @0dB Atten Shoulders Level @-3dB Shoulders
71 +10 dBm -45 dB +7 dBm -50 dB
146 +12 dBm -45 dB +9 dBm -50 dB
437 +14.5 dBm -45 dB +11.5 dBm -50 dB
1255 +11 dBm -45 dB +8 dBm -45 dB
