Es'hail-2 LNBs and Antennaes
Revision as of 22:16, 1 January 2019 by G8GKQ (talk | contribs)
Octagon LNB
References:
https://f5xg.jimdo.com/antennes/syst%C3%A8me-duo-bande-2-4ghz-10ghz/
http://www.hb9afo.ch/articles/pll-lnb/10ghz_pll-lnb.htm
https://forum.amsat-dl.org/index.php?thread/7-modification-of-octagon-oslo-pll-lnb-for-external-frequency-reference/
We use these LNBs on the FRARS EME system. Attempts to modify the LNB to interface to WG16 or different circular feeds usually lose about 0.3-0.4dB. We are currently trying to work out why... Matching screws do not improve it, so I don't think it is the Lambda-g......
The Octagon "Quad LNB Green" Model OQSLG Green HQ can easily be modified to run from an external 25 MHz reference fed in on one of its F-type sockets, while still providing 3 horizontal or vertical outputs. This LNB is available (Jan 2019) from Amazon UK for under £15. The item title is "Octagon 0.1db Quad High Gain HD Ready Universal LNB", but check carefully that you get the OQSLG model.
804px
