Using LimeSDR with Portsdown
With the Portsdown Filter Modulator board being discontinued (Jan 2019 - no further FM boards will be available after the current shop stock is sold) it is envisaged the LimeSDR Mini will become the standard modulator for use with the Portsdown system and will be available for purchase in the BATC members shop.
The LimeSDR Mini is slightly more expensive than the Portsdown Filter Modulator board but does not require the use of a separate ADf4351 Local Oscillator module and a Local Oscillator filter board. Note - the LimeSDR Mini is available from the BATC members shop at a slightly discounted price compared to the normal retail price from the US plus shipping and 22% import duty charges.
Hardware Installation
The USB plug on the LimeSDR Mini is vulnerable to mechanical stress; it is recommended that the LimeSDR Mini (or LimeSDR USB) be mounted in a protective box with strain relief for a USB lead. One possible mechanical configuration is illustrated below.
Installing the Lime Software
The LimeSuite software version 18.10.0 is loaded as part of the normal Portsdown build and update process.
Lime Configuration Menu
The "Update Lime FW" button updates the Lime SDR firmware and gateware to the appropriate version for the installed LimeSuite. For Portsdown software versions 201811300 and later, the correct versions are shown below. You should see the same screen after selecting "Lime FW Info". Note that BATC Shop LimeSDR Minis may display Hardware Version 2, and Gateware version 26 - this is being investigated.
Transmitting
Select Lime Mini or Lime USB from the "Output to" Menu. The detected device should be "not greyed out". On Menu 1, you will see the Lime Gain button for the appropriate band (distinct Lime Gains between 0 and 100 are stored for each band). This has yet to be calibrated, but a setting of 88 is a good starting point for between 1 and 5 dBm of output at 437 MHz.
Limitations
System Diagram
Acknowledgements
