Revision as of 09:25, 23 January 2019 by G8GTZ (talk | contribs)
The project, which was featured in the June 2017 issue of the RSGB's Radcom magazine, involves some basic construction and is based around a Raspberry Pi with a touchscreen and uses a LimeSDR Mini - outline specification is as follows:
System overview
At the heart of the The Portsdown Transmitter is a Raspberry Pi (RPi) computer running a BATC customised version of the F5OEO rpidatv software. The choice of the RPi is primarily due to the fact that it has an on-board MPEG-4 (H264) encoder and the versatile hardware interface (GPIO) capabilities. The original block diagram is shown here:
From January 2019 the custom BATC Filter Modulator board has been replaced by a LimeMiniSDR. This covers a wider frequency range and adds DVB-S2 capability but limits the maximum symbol rate to 1.5Ms depending up on transmission modes.
Touch screen control
Modulator and Filter board
The output from the RPi is connected to a LimeSDR Mini (or the original Filter Modulator board) which modulates the RF carrier and produces the DVB-S DATV signal.
Audio and video inputs
The Portsdown transmitter will take audio and video inputs from the RPi camera, an EasyCap USB dongle and a USB sound card / dongle - all these are readily available from ebay and Amazon.
Next steps?
Or if you want to print off an overview of the project, we've produced a File:Portsdown Brochure V3.pdf 2 page introductory brochure which also includes a spec sheet for the Portsdown transmitter.
Finally TXfactor have produced a great video introducing and explaining Portsdown and ATV in action - take 15 minutes to watch it here.
