Es'hail-2 LNBs and Antennaes
Octagon LNB
References:
G4JNT's Modifications and Measurements
G4JNT's Modification for an External LO (for 27 MHz Octagon LNB)
F5XG's Dual Band Feed for Es'hail-2
HB9AFO's Modifications for an external LO on an Avenger LNB (in French)
https://forum.amsat-dl.org/index.php?thread/7-modification-of-octagon-oslo-pll-lnb-for-external-frequency-reference/
CQ-TV 261 page 36 had an article by Dave G4FRE on locking the 27MHz Octagon.
We use these LNBs on the FRARS EME system. Attempts to modify the LNB to interface to WG16 or different circular feeds usually lose about 0.3-0.4dB. We are currently trying to work out why... Matching screws do not improve it, so I don't think it is the Lambda-g......
The LNB should then be tested with a 25 MHz reference. Note that it will not now operate without a reference signal. If all is well, the cover can be replaced. Before putting the LNB on the dish, I sealed around the cover using a neutral cure silicone sealer. Screwfix 83710 is cheap and does the job.
Suitable 25 MHz Reference
The low pass filter had 5 elements, 288 pf to ground on the input, a series inductor of about 10 turns on a 4 mm core, 407 pf to ground in the centre, then another identical series inductor and 288 pf on the output.
Phase Noise
