MiniTioune
The MiniTioune receiver project, developed by Jean-Pierre F6DZP, consists of the home constructed MiniTiouner hardware which interfaces via a standard USB 2.0 port to a Windows PC running the MiniTioune software.
Hardware <------------> Windows Software
It will receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second.
It can be used to receive satellite broadcasts, "normal" DATV signals and is the ONLY system capable of receiving Reduced Bandwidth (RB-TV) transmissions.
Definitions
  • MiniTioune = PC software
Hardware overview
The MiniTiouner hardware has no surface mount components and requires medium level constructional skills. BATC sells the hard to get components and the rest are available from normal suppliers.
Full details of the current version 2 MiniTiouner hardware and build information are available here - new builders should start on this page.
Details of the previous hardware versions are available here.
Full details of the MiniTioune software which is free to download and designed to be used with the MiniTiouner hardware are available here MiniTioune software.
Band Pass filters
Receive upconverters
The Serit tuner currently on sale in the shop covers 144 - 2450 MHz and does not require any external frequency converters.
However, the original Sharp and Eardatek tuner components (also called NIM) used in MiniTiouner cover a maximum of 650 to 2600 MHz. This covers the 23cms (1.3 GHz) and 13cms (2.3 GHz) amateur bands it does not provide coverage of 146 (2mts) and 437 MHz (70cms) where the majority of ATV operation takes place. Therefore we need to use an upconverter in front of the tuner which converts 146 MHz and 437 MHz up to an L band frequency that the MiniTiouner will receive.
