To build the unit you only need to buy the following components from the BATC shop [[1]] and then download the free MiniTioune software.
- The ready programmed USB interface.
- The version 2 main PCB.
- The Serit tuner or NIM covering 143 - 2450 MHz. NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
- The unit uses an adjustable MCP1826 as the 1v regulator, which can be hard to find.
Parts list and schematic
The parts list and schematic are available for download:
The small regulator module is available from ebay - search for "MP1584 step down buck regulator".
Mike, G0MJW, has written some instructions on building and testing the board - download them here File:Notes on building the BATC v2 Minitiouner.pdf
Setting up the hardware
MiniTiouner version 0.8 software
A small modification must be carried out before this version 2 hardware can be used with the MiniTiouner version 0.8 software (latest version released Spring 2018).
A resistor between 5.6k and 12K must be fitted between CN2 Pin 19 on the USB module (U6 on the BATC PCB) and ground as shown in the pictures by G7JTT and G1MEG.
On the air
