MiniTioune software
Revision as of 15:16, 9 February 2019 by G8GTZ (talk | contribs) (→Other controls)
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP.
The Software is hosted on the VivaDATV forum. You need to register and be given a log-in to download the software.
Once you have a log-in, V0.8 (latest version at Dec 2018) can be downloaded from here: http://www.vivadatv.org/viewtopic.php?f=60&t=521
Version 0.8
You will to do a small modification to the hardware to run Version 0.8 software - see MiniTiouner_hardware_Version_2#MiniTiouner_version_0.8_software
Previous versions
You will need Version v0.6 or newer if you have built a MiniTiouner Version 2 board with a Serit tuner (or a Serit tuner on a version 1 board with adapter card). Full installation procedure is at the bottom of this page.
Connecting the hardware
It is absolutely essential you use a high quality USB cable or the program will frequently freeze and crash with no warning
The recommended cable is a Lindy Cromo Lindy cable USB 2.0 type A/mini-B 1m long.  https://www.lindy.co.uk/cables-adapters-c1/usb-c449/1m-cromo-usb-2-0-type-a-to-mini-b-cable-p6866
  • DVB mode - DVB-S or DVB-S2
Start the program and you should see the please wait message - the current Serit = 20 seconds, previous tuners = 10 seconds. If you get the USB error message then you hardware is not connected.
  • DVB mode - tick the correct mode box. Currently all DATV signals are currently DVB-S and most domestic satellite signals are DVB-S2. For ATV operation make sure the DVB-S box is ticked and not auto.
If you are using a Serit tuner, which covers 144 - 2550 MHz without any upconverters, make sure you have NO offset in the white box under the frequency box.  If there is a a number present simply enter "00000000" to overwrite it.  If you are using a Sharp tuner with an upconverter you will need to enter the L band frequency in the green box or the receive frequency in the green box plus LO offset in the white box.
The 3 "lights" at the bottom left of the screen should now turn green, the meters should indicate signal level and MER, you should see dots in the 4 quadrants of the constellation window and the Viterbi error bar graph should go green.
  • Place a jumper on J3, which is near the 12v power socket. Check that there is now 12v on the upper NIM F socket.
  • Connect the upper NIM socket to a Sky dish.
  • Start the MiniTioune software.
  • In the frequency setting area in the top left of the screen, put 09750000 into the OFFSET box.
  • Click the PLUS / MINUS indicator next to it so that it shows MINUS.
  • Put 10758000 into the FREQ box.
  • Put 22000 into the SR box.
Other controls
Set of soft controls located at the bottom right of the screen.
A typical display from the Data reader
  • FEC selected on startup
  • DVB mode on start up
  • DC volts on tuner output
Web monitor
The web monitoring panel will now show your call sign and locator - tick the "auto" box and turn the monitor switch on.
Expert Mode
To be completed.....
Ken W6HHC has a written a very comprehensive user guide for MiniTiouner-Express system which uses the same software as the BATC hardware - this is available here https://www.datv-express.com/uploads/UserGuide/MiniTouner-Express%20User-Guide-draft15.pdf
Software Installation V7 and before only
For a very comprehensive guide on the software installation, see the user guide written by W6HHC - http://www.w6ze.org/DATV/InstallingMiniTiouner_onWin10.pdf
