Es'hail-2 Ground Station
The BATC WebSDR & Spectrum Monitor can be accessed at: https://eshail.batc.org.uk/
Current Status
The RF hardware was installed at Goonhilly Earth Station in August 2018 and installation was completed in January 2019 with the facility launched on 10th February 2019.
The dish has been pointed at 26 degrees East (the planned Es'hail-2 location) and tested by receiving signals from BADR-4.
Technical Details
RF Front End
The hardware consists of a 1.3 Metre offset-feed dish with a dual LNB.
LNBs are locked to 25MHz output from LeoBodnar GPSDO.
2x coax used for horizontal & vertical feed.
Receivers
2x AirSpy USB SDR Receiver, locked to 10MHz output from LeoBodnar GPSDO.
The indoor LNB Power Unit has been constructed:
The GPS reference is a Leo Bodnar unit programmed to produced 10 MHz (for the Airspys) and 25 MHz (for the LNB, but not implemented yet). The settings for the reference to produce these 2 frequencies were not straightforward (as the 2 outputs on the Leo Bodnar unit need to be linked) but are here for reference:
Host PC
PC Hardware
i7-2600 CPU
16GB DDR3 RAM
Intel DQ67SW Motherboard
500GB Samsung 850 EVO SSD
750W Corsair TX Power Supply
PC Software
Ubuntu Server 18.04
Nginx Web Server
airspy_tcp fork (source)
Network
TBC
More Photos
