Es'hail-2 Ground Station
The BATC WebSDR & Spectrum Monitor are located at the icon Goonhilly Earth Station in Cornwall (IO70JB). The equipment is housed in a room dedicated to amateur radio infrastructure in what was the control room for the now defunct GHY2 90 ft dish antennae which was built in 1969.
As well as the Es'hail-2 (now known as Qatar Oscar 100) webSDR and spectrum monitor the amateur radio facility houses an AMSAT-UK Funcube ground station and an HF Kiwi WebSDR.
Current Status
The RF hardware was installed at Goonhilly Earth Station in August 2018 and installation was completed in January 2019 with the facility launched on 10th February 2019.
Technical Details
Dish
The original 1.2mt dish
The original dish installed in August 2018 was a consumer model and suffered damage in heavy winds during October 2018. This was replaced in January 2019 with a heavy duty Hirschmann 1.3mt offset dish.
RF Front End
The hardware consists of a 1.3 Metre offset-feed dish with a dual LNB.
LNBs are locked to 25MHz output from LeoBodnar GPSDO.
2x coax used for horizontal & vertical feed.
Receivers
2x AirSpy USB SDR Receiver, locked to 10MHz output from LeoBodnar GPSDO.
The indoor LNB Power Unit has been constructed:
The GPS reference is a Leo Bodnar unit programmed to produced 10 MHz (for the Airspys) and 25 MHz (for the LNB, but not implemented yet). The settings for the reference to produce these 2 frequencies were not straightforward (as the 2 outputs on the Leo Bodnar unit need to be linked) but are here for reference:
Host PC
PC Hardware
i7-2600 CPU
16GB DDR3 RAM
Intel DQ67SW Motherboard
500GB Samsung 850 EVO SSD
750W Corsair TX Power Supply
PC Software
Ubuntu Server 18.04
Nginx Web Server
airspy_tcp fork (source)
Network
TBC
More Photos
