Es'hail-2 Ground Station
The Narrowband WebSDR can be accessed at https://eshail.batc.org.uk/nb/, the Wideband Spectrum Monitor at https://eshail.batc.org.uk/wb/
The equipment is housed in a room dedicated to amateur radio infrastructure in the original control building for the now defunct GHY2 90 ft dish antennae, built in 1969.
As well as the Es'hail-2 (now known as Qatar Oscar 100) WebSDR and spectrum monitor, the station houses an AMSAT-UK Funcube ground station and an HF Kiwi WebSDR with GPS TDOA.
RF System
"[Block Diagram Here]"
Dish
RF Front End
Receivers
GPS reference
Computer System
- Intel i7-2600 CPU
- 16GB DDR3 RAM
- Intel DQ67SW Motherboard
- 500GB Samsung 850 EVO SSD
- Ubuntu Server 18.04
- Nginx Web Server & Reverse Proxy
- WebSDR by PA3FWM (homepage)
- FFT Spectrum Server (source coming soon)
Networking
Goonhilly Earth Station has 2x diverse redundant 10Gb links into JANET PoPs. They have been kind enough to give us a dedicated IP address and access to >300Mb/s of up & down bandwidth for use by the station.
A high-bandwidth Leo Bodnar NTP Server also provides NTP service to the station & the worldwide NTP Pool.
