2-Way RF Switch
Revision as of 13:30, 17 April 2019 by G8GKQ (talk | contribs)
The 2-way RF switch is a new addition to the Portsdown system. It allows a single PA (or the 4-way or 8-way RF switch) to be driven from either the Portsdown Filter-modulator board or the LimeSDR without reconfiguration. So, it is intended as 2 inputs, one output, rather than the single input, multiple outputs of the 4-way and 8-way switches.
This block diagram shows a comprehensive arrangement with all the features. Many of the blocks are optional – it depends on your requirements.
The 2-way switch decodes the signals sent on the symbol rate switching lines (detecting all 3 high, which was previously unused) and selects the LimeSDR output, rather than the Filter-modulator board, when required.
Schematic
Test results
The test results for the switch (when running from 3.3v) were:
Frequency Insertion Loss Isolation
71 MHz < 0.5 dB 36 dB
146 MHz < 0.5 dB 35dB
437 MHz 0.8dB 35dB
1255 MHz 1.5dB 21dB
2405 MHz 3.5dB 19dB
The insertion loss at 2405 MHz can be reduced by 0.5 dB by trimming the centre pins of the SMA connectors to be flush with the underside of the PCB. A further improvement could probably be made by trimming the RF tracks on the top of the PCB so that they do not extend beyond the SMA centre pin.
The PCB for the RF switch is available from the BATC shop.
