IARU ATV contest
Who can enter?
What Bands are in Use?
The IARU region 1 Contest includes all harmonised amateur bands above 400 MHz.
Note: Only the UK have the 146MHz band and it is not included in the contest.
Signal reports
Time of contest
Submitting an entry
Ideally you will submit an entry on the official Excel Spreadsheet which you can download from here ATV-contest-log-callsign-20190608.xls.
Alternatively, simply email in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received to contests@batc.tv.
Contact scoring
  • For contacts on the 71 and 146 MHz bands: 2 points/kilometre (BATC Contest only)
2018 contest results
And a full list of the UK results can be found here.
2017 contest results
The number of stations entering the contest is increasing each year:
2014 = 33
2015 = 42
2016 = 52
2017 = 95
2018 = 100
Certificates
More information
