IARU ATV contest
Revision as of 13:28, 22 May 2019 by G8GKQ (talk | contribs)
File:2018 IARU ATV Map.png
Who can enter?
What Bands are in Use?
The IARU region 1 ATV Contest includes all harmonised amateur bands above 400 MHz.
Note: Only the UK has the 71 and 146MHz bands and so are not included in the IARU ATV contest.
Signal reports
Time of contest
Submitting an entry
While the important thing is that you get "on the air" at sometime over the weekend, it would be great if you also took the time to submit an entry, even if it is only for a single 5km QSO across town using the 5665MHz drone equipment you just got working! That way we can show to Ofcom and other users that there is real activity on the ATV bands and also so the UK can have highest number of entries in the contest!
Ideally you will submit an entry on the official Excel Spreadsheet which you can download from here Media:ATV-contest-log-callsign-20190608.xls.
Alternatively, simply email in a list of your contacts including times, frequencies, callsigns, locators and numbers sent and received to contests@batc.tv.
Contact scoring
  • For contacts on the 71 and 146 MHz bands: 2 points/kilometre (BATC Contest only)
2018 contest results
And a full list of the UK results can be found here.
2017 contest results
The number of stations entering the contest is increasing each year:
2014 = 33
2015 = 42
2016 = 52
2017 = 95
2018 = 100
Certificates
More information
