OBS - Open Broadcast Studio
Open Broadcast Studio is a free and open source software for video recording and live streaming.
It enables high performance real time video/audio capturing and mixing. Create scenes made up of multiple sources including window captures, images, text, browser windows, webcams, capture cards and more.
Download
More details on the features and the program download from https://obsproject.com/
Using OBS with Portsdown
OBS can be used as a fully flexible video source for the Portsdown DATV system. The program interfaces in to the Portsdown over a wired network connection via an ffmpeg script developed by Evariste F5OEO.
Preparing the system
As well as downloading OBS and ensuring it runs on your PC, you will also need to download ffmpeg from https://ffmpeg.org/ - ffmpeg should then be installed on your PC at C:/ffmpeg
It is also useful to have VLC on the PC for testing - https://www.videolan.org/vlc/index.en-GB.html
You will need to setup the Portsdown to talk to your PC via a network cable, WiFi wont work reliably. I set the Portsdown up with a fixed IP of 10.0.0.1 by adding the text ip=10.0.0.1 to the cmdline.txt file found in the root of your SD card.
Once you have set the Portsdown up and can confirm the network is working, you need to set up OBS.
OBS configuration
With OBS running click on the profile tab and then rename the default profile to 250Ks@3/4FEC.
Now click on the file tab and go to show the profile folder. Within that window you will see a file basic.ini, right click edit then you should be able to copy and paste the above text into this file.
You can set the preview screens up to what ever takes your fancy but the FFRescaleRes should be appropriate for the SR in use so 768x576 or 352x288 are better suited to SR333/250 where as 1280x720 is better left to SR's of 500Ks and above.
You can now duplicate this profile and rename them to suit your own choice of SR/FEC combination, I have 250Ks@3/4FEC, 333Ks@3/4FEC,500Ks@1/2FEC,500Ks@3/4FEC and 1Ms@1/2.
For each profile you will need to change the muxrate and FFVBitrate (video bitrate) values for your given choice of SR/FEC. Use this site http://www.satbroadcasts.com/DVB-S_Bitrate_and_Bandwidth_Calculator.html to work out your own choice of SR/FEC combinations.
The Netto TS bitrate is what you need but in Kmps so multiply by 1000000 then enter this as your new muxrate, to work out the FFVBitrate multiply muxrate by 0.0006 and round up to just 3 digits.
Once OBS is set up you can test it's all working with VLC set to receive an network connection on udp://230.0.0.11:20000 and hitting the start recording button on OBS.
