Revision as of 09:59, 14 August 2019 by G8GTZ (talk | contribs) (→‎On the air)
To build the unit you only need to buy the following components from the BATC shop [1] and then download the free MiniTioune software.
  • The version 2 main PCB.
  • The Serit tuner or NIM covering 143 - 2450 MHz. NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
  • The unit uses an adjustable MCP1826 as the 1V regulator, which can be hard to find.
Parts list and schematic
Mike, G0MJW, has written some instructions on building and testing the board - download them here Notes on building the BATC v2 Minitiouner. This pdf includes a Panel layout for the Hammond Box.
Setting up the hardware
G1MEG 180px\G7JTT
On the air
LNB power supply with current limit
