To build the unit you only need to buy the following components from the BATC shop [1] and then download the free MiniTioune software.
- The ready programmed USB interface.
- The version 2 main PCB.
- The Serit tuner or NIM covering 143 - 2450 MHz. NOTE - due to different pinouts the previously available Sharp and Eardetek NIMs will NOT work with the version 2 board
- The unit uses an adjustable MCP1826 as the 1V regulator, which can be hard to find.
Parts list and schematic
Mike, G0MJW, has written some instructions on building and testing the board - download them here Notes on building the BATC v2 Minitiouner. This pdf includes a Panel layout for the Hammond Box.
Setting up the hardware
On the air
LNB power supply with current limit for MiniTiouner
A number of people on the BATC forum have reported their Serit tuners are no longer outputting the LNB voltage from one of the F sockets. The cause is inevitably an open circuit inductor (L101 or L102) after the output has been accidently short circuited.
In CQ-TV 265 Colin, G4KLB, described an add on PCB to provide current limiting using the RT5047 device.
The PCB will be available form the BATC shop.
Parts list File:RT5047 LNB POWER REV 2-1 PARTS.xlsx
Schematic PDF File:RT5047 LNB Power.pdf
Schematic
PCB fitted to standard enclosure
PCBs
Wiring to MiniTiouner v2.0
