G4WIM PA controller
Configurations
The resulting system can be configured in three ways
- Full remote control of the PA and shack monitoring of vital signs – using radio link.
- When PA is in the shack, local control and monitoring - no radio link.
- Remote control of PA by means of DC down the coax – no radio link or remote monitoring
The most likely use cases are 1 and 2. In this article I refer to the PA with associated control and telemetry hardware as the MASTER and the remote display / control in the shack as the SLAVE.
When used as #2 above there is no SLAVE and the MASTER serves as control and display.
In all cases it allows monitoring of the following analogue signals • Vdd, 100mV resolution • Idd, 100mA resolution • PA temperature, 0.1C resolution • Bias voltage, 10mV resolution for LDMOS, 1V for Pyro Jo • RF power (forward or reverse but not both – depends on HW implementation) • Fan status on or off • Standby status on or off
Amplifier choices
The design was initially conceived for a Pyro Jo PA which needs 24V DC bias to activate it, subsequently it was modified to provide a temperature compensated bias for LDMOS FET’s. Basically for the LDMOS FET use the temp compensated bias circuit and for the Pyro JO PA use the 24V DC device – one or the other NOT both. See schematics for more detail.
- Link 3 jumper when installed configures the firmware for Pyro Jo PA and when not installed configures for LDMOS operation.
- Link 4 jumper when installed configures the firmware for SLAVE operation and when not installed configures for MASTER operation.
Documentation
File:G4WIM PA CONTROLLER V1-0 SS.png
Bill of material File:G4WIM PA Controller BOM.docx
Schematics File:G4WIM PA CONTROLLER V1-0 SHT2.pdf
File:G4WIM PA CONTROLLER V1-0 SHT3.pdf
File:G4WIM PA CONTROLLER V1-0 BOM DK.xlsx
