G4WIM PA controller
Revision as of 18:49, 10 September 2019 by G8GTZ (talk | contribs) (→Documentation)
Configurations
The resulting system can be configured in three ways:
  • Full remote control of the PA and shack monitoring of vital signs – using radio link.
  • When PA is in the shack, local control and monitoring - no radio link.
  • Remote control of PA by means of DC down the coax – no radio link or remote monitoring
Monitoring
  • Vdd, 100mV resolution
  • Idd, 100mA resolution
  • PA temperature, 0.1C resolution
  • Bias voltage, 10mV resolution for LDMOS, 1V for Pyro Jo
  • RF power (forward or reverse but not both – depends on HW implementation)
  • Fan status on or off
  • Standby status on or off
Amplifier choices
The design was initially conceived for a Pyro Jo PA which needs 24V DC bias to activate it, subsequently it was modified to provide a temperature compensated bias for LDMOS FET’s. Basically for the LDMOS FET use the temp compensated bias circuit and for the Pyro JO PA use the 24V DC device – one or the other NOT both. See schematics for more detail.
  • Link 3 jumper when installed configures the firmware for Pyro Jo PA and when not installed configures for LDMOS operation.
  • Link 4 jumper when installed configures the firmware for SLAVE operation and when not installed configures for MASTER operation.
File:G4WIM PA CONTROLLER V1-0 SS.png
Documentation
Bill of material
Schematics
Source code
File:BATC_Unified_PA_Controller.zip
