G4WIM PA controller
Revision as of 20:42, 10 September 2019 by G8GTZ (talk | contribs) (→Documentation)
Configurations
The resulting system can be configured in three ways:
  • Full remote control of the PA and shack monitoring of vital signs – using radio link.
  • When PA is in the shack, local control and monitoring - no radio link.
  • Remote control of PA by means of DC down the coax – no radio link or remote monitoring
Monitoring
  • Vdd, 100mV resolution
  • Idd, 100mA resolution
  • PA temperature, 0.1C resolution
  • Bias voltage, 10mV resolution for LDMOS, 1V for Pyro Jo
  • RF power (forward or reverse but not both – depends on HW implementation)
  • Fan status on or off
  • Standby status on or off
Amplifier choices
The design was initially conceived for a Pyro Jo PA which needs 24V DC bias to activate it, subsequently it was modified to provide a temperature compensated bias for LDMOS FET’s. Basically for the LDMOS FET use the temp compensated bias circuit and for the Pyro JO PA use the 24V DC device – one or the other NOT both. See schematics for more detail.
  • Link 3 jumper when installed configures the firmware for Pyro Jo PA and when not installed configures for LDMOS operation.
  • Link 4 jumper when installed configures the firmware for SLAVE operation and when not installed configures for MASTER operation.
File:G4WIM PA CONTROLLER V1-0 SS.png
Documentation
Bill of material
Schematics
Source code
File:Atmel_BATC_Unified_PA_Controller.zip
The radio link uses an nRF905 and Atmel nano – this solution is a copy of this design http://blog.zakkemble.net/nrf905-avrarduino-librarydriver/comment-page-1/ but with minor code changes. It is very easy to build / modify using the Arduino environment. The only minor code change required is to remove the “TO” time out message being sent. If this line is not commented the atmega 328 thinks the link is still good as it’s getting traffic.
Comment out line 110 as per below:
if(timeout) // Timed out{Serial.println(F("TO"));break;}
Wireless Serial Link Arduino code is found here: https://github.com/zkemble/nRF905/tree/master/arduino/nRF905/examples/wirelessSerialLink
