G4WIM PA controller
Configurations
The resulting system can be configured in three ways:
  • Full remote control of the PA and shack monitoring of vital signs – using radio link.
  • When PA is in the shack, local control and monitoring - no radio link.
  • Remote control of PA by means of DC down the coax – no radio link or remote monitoring
Monitoring
  • Vdd, 100mV resolution
  • Idd, 100mA resolution
  • PA temperature, 0.3C resolution
  • Bias voltage, 10mV resolution for LDMOS
  • RF power (forward or reverse but not both – depends on HW implementation)
  • Fan status on or off
  • Standby status on or off
Amplifier choices
The design was initially conceived for a Pyro Jo PA which needs 24V DC bias to activate it, subsequently it was modified to provide a temperature compensated bias for LDMOS FET’s. Basically for the LDMOS FET use the temp compensated bias circuit and for the Pyro JO PA use the 24V DC device – one or the other NOT both.
See CQ-TV article and schematics for more detail.
Documentation
Bill of material
File:G4WIM PA CONTROLLER V2-0 BOM.xlsx
Schematics
Source code
File:BATC_PA_Controller_Firmware_V2.zip
The radio link uses an nRF905 + Atmel nano combined with some custom code in an ATmega 328. The Atmel nano code is based on this solution http://blog.zakkemble.net/nrf905-avrarduino-librarydriver/comment-page-1/
IMPORTANT - after building several of these links it became apparent that the timings required for the nRF905 are not the same for all modules. To fix this issue I've created a new improved version of Zak's code for the Atmel Nano. The code for the ATmega328 has also been changed to match. Using Zak Kemble code in the Arduino environment might work - but it is better to use his C code version with my modifications.
Source code and hex files will be available at the above link.
Any chips supplied by the BATC shop will have the correct code installed for both the ATmega and Nano - you cannot mix and match Arduino code with the ATmega C code.
