G4WIM PA controller
Revision as of 18:42, 18 October 2019 by G8GTZ (talk | contribs) (→Documentation)
Configurations
The resulting system can be configured in three ways:
  • Full remote control of the PA and shack monitoring of vital signs – using radio link.
  • When PA is in the shack, local control and monitoring - no radio link.
  • Remote control of PA by means of DC down the coax – no radio link or remote monitoring
Monitoring
  • Vdd, 100mV resolution
  • Idd, 100mA resolution
  • PA temperature, 0.3C resolution
  • Bias voltage, 10mV resolution for LDMOS
  • RF power (forward or reverse but not both – depends on HW implementation)
  • Fan status on or off
  • Standby status on or off
Amplifier choices
The design was initially conceived for a Pyro Jo PA which needs 24V DC bias to activate it, subsequently it was modified to provide a temperature compensated bias for LDMOS FET’s. Basically for the LDMOS FET use the temp compensated bias circuit and for the Pyro JO PA use the 24V DC device – one or the other NOT both.
See CQ-TV article and schematics for more detail.
Documentation
Bill of material
File:G4WIM PA CONTROLLER V2-0 BOM.xlsx
Schematics
File:G4WIM PA CNTR V1-0 Sch Sht 1.pdf
File:G4WIM PA CNTR V1-0 Sch Sht 2.pdf
File:G4WIM PA CNTR V1-0 Sch Sht 3.pdf
Source code
File:BATC_PA_Controller_Firmware_V2.zip
The radio link uses an nRF905 + Atmel nano combined with some custom code in an ATmega 328. The Atmel nano code is based on this solution http://blog.zakkemble.net/nrf905-avrarduino-librarydriver/comment-page-1/
IMPORTANT - after building several of these links it became apparent that the timings required for the nRF905 are not the same for all modules. To fix this issue I've created a new improved version of Zak's C code for the Atmel Nano. The code for the ATmega328 has also been changed to match. Using Zak Kemble code in the Arduino environment might work - but it is better to use his C code version with my modifications as documented and provided in the above source code link.
When programming the hex files make sure the fuse /8 is unchecked and that fuse for external 8MHz xtal is selected as the clock source. If building your own code from source using Atmel Studio V7.0 set optimisation to -OS (optimise for size).
Any chips supplied by the BATC shop will have the correct code installed for both the ATmega and Nano - you cannot mix and match Arduino code with the ATmega C code.
