The method oulined here will also work with other DATV tranmit systems such as the F5OEO custom firmware for the Adalm Pluto.
Using vMix with the Portsdown DATV system
Vmix
ffmpeg
ffmpeg script or batch file
The last installation step on the PC is to install the windows batch file which will control ffmpeg.
Original Portsdown script
Save the file.
Using the system
Encoding Options
- MPEG-2 with added 333kS/S symbol rate: File:VMix2PortsdownExtendedSR.zip
- H.264 encoding: File:VMix2PortsdownH264ExtendedSR.zip
- Adding text overlays (e.g. for callsign, locator): see blog post by Chris MW0LLK for how to add text to the batch file (http://www.tannet.org.uk/using-ffmpeg-to-generate-a-transport-stream-more-details-and-how-to-add-text-overlays/)
More to follow..............
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
