The method oulined here will also work with other DATV tranmit systems such as the F5OEO custom firmware for the Adalm Pluto.
Using vMix with the Portsdown DATV system
Vmix
ffmpeg
ffmpeg script or batch file
The last installation step on the PC is to install the windows batch file which will control ffmpeg.
Original Portsdown script
You can download it from here File:VMix2Portsdown.zip Unzip the file and save the and save the vMix2Portsdown.bat file to a logical place of your choice. You will need to make some amendments to the file; do this by right-clicking and selecting edit. Near the top of the file replace the callsign G8GKQ with your callsign; then replace the IP address (192.168.2.111) with the IP address of your Portsdown TX RPi. This IP address is displayed when you change the Portsdown video source to IPTSIN (don't forget to press the space bar to change the selection!). You may want to adjust the aspect ratio of the output. This is done by editing the line...
Save the file.
Using the system
Encoding Options
More to follow..............
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
