Vmix
ffmpeg
ffmpeg script or batch file
Original Portsdown script
Save the file.
Using the system
Encoding Options
- MPEG-2 with added 333kS/S symbol rate: File:VMix2PortsdownExtendedSR.zip
- H.264 encoding: File:VMix2PortsdownH264ExtendedSR.zip
- Adding text overlays (e.g. for callsign, locator): see blog post by Chris MW0LLK for how to add text to the batch file (http://www.tannet.org.uk/using-ffmpeg-to-generate-a-transport-stream-more-details-and-how-to-add-text-overlays/)
More to follow..............
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
