Vmix
ffmpeg
ffmpeg script or batch file
An example script from Thomasz SPxxx is available for download here: File:sample 333ks 23 s2 440.zip
  • Enter your own station details
  • Line 17 - enter the IP address of your Portsdown / Pluto etc
  • Line 59 - set the video resolution to match the Vmix external output resolution.
Original Portsdown script
You can download it from here File:VMix2Portsdown.zip Unzip the file and save the and save the vMix2Portsdown.bat file to a logical place of your choice. You will need to make some amendments to the file; do this by right-clicking and selecting edit. Near the top of the file replace the callsign G8GKQ with your callsign; then replace the IP address (192.168.2.111) with the IP address of your Portsdown TX RPi. This IP address is displayed when you change the Portsdown video source to IPTSIN (don't forget to press the space bar to change the selection!). You may want to adjust the aspect ratio of the output. This is done by editing the line...
Save the file.
Encoding Options
Using the system
More to follow..............
/home/pi/rpidatv/scripts/a.sh
sudo killall rpidatv
